ROON ARC does not connect using Roon Optimized Core Kit
Roon Server Machine
Roon Optimized Core Kit Intel NUC
Wired Network
I have been using the Roon Optimised Core Kit on my Intel NUC for a few days now, the Core Kit is running but Roon ARC does not connect. this was still possible when I used my 1621xs Synology as a Roon server, I forwarded the port 55000 on the NUC in the router and logged in again to my Roon account, but all this is of no use Roon ARC does not connect.
@Michael_Herzog, it looks like you haven’t filled in any details in your request for assistance. Please complete the template, and post any error messages you see, including the diagnostics message in Roon Remote under Settings > Roon ARC.
Please fill out the questions from the posting template, it’s impossible to help if we have to guess your setup. I have copied the questions from ARC: Port Forwarding Help which also include the network setup
Roon Server Machine
<!-- Include your operating system and machine info (Model, CPU, RAM) →
<!-- Your network gear (model of routers/switches), if on WiFi/Ethernet, and if you are using a VPN–>
  1. Who is your internet service provider?
  2. Please list the make and model of your modem and router?
  3. Do you have any additional network hardware, like additional routers or managed switches?
  4. Does your network have any VPNs, proxy servers, or enterprise-grade security?
<!-- Specify what devices you’re using and their connection types, like USB/HDMI/Chromecast, etc.) →
Description of Issue -
What is the exact port forwarding error message you see in the Roon Settings → ARC tab?
<!–Tell us about the problem you’re having in as much detail as possible. Screenshots are always appreciated! →
Have you removed the old ARC routing rule for the (presumably now defunc) synology Roon server. If not, have you got duplicate routing entries for port 55000 routing to two different servers?
If this is the case, you will need to do one of:
  1. Remove the original port forwarding rule.
  2. Change the port number in both the Roon Server → Settings → ARC page and the Router port forwarding rule to something other than 55000 - say 55001.
Hello
thank you very much for the fast response. :+1:
it works now i resest the ARC Network and
now it uses Port 50002
best regards
Michael
