What kind of performance/speed issue are you experiencing?
· The app takes a long time to respond to commands
Please try to reboot your Roon Server
· No, the issue is still the same even immediately after a reboot
Please try to reboot your networking gear (Router/Switches/etc.)
· No, the issue is still the same even after a reboot
Is there any change in behavior if you try to navigate to Roon Settings -> Library and set both Background and On-Demand Audio Analysis to Throttled or Off?
Does the issue happen on multiple Roon Remotes (controllers) or just one?
· I only have one Roon remote to test with
Please try to restart your Roon Remote (controller) app
· No, the issue is still the same even after a restart
What is the operating system of your Roon Remote (controller)?
· iOS
Reinstall Mobile Roon Remote App
· No, I am still having the issue even after reinstalling
Router Domain Name System (DNS) change
· I was able to change my router's DNS servers but it did not help
· Roon on a NAS (Synology, QNAP, ASUSTOR)
Roon ARC often becomes extremely laggy and slow to respond. It can take anywhere from 2 seconds to 30 seconds for it to respond to a touch event. When trying to play music, it will sometimes start playing (several seconds after pressing the button) but stop after 10-20 seconds. Sometimes painstakingly enabling offline mode (this takes MINUTES with the slowness) makes things go fast again. But then after restarting ARC starts in offline mode and can be slow again. This happens most often when there is no Wi-Fi (only LTE connectivity).
Dear Roon Team, please understand that this is a deal-breaker. Roon ARC overall has an abysmal reliability record. It also sometimes refuses to start saying "There is an issue with your roon server" (there is no issue) and telling me to go to the Roon app to fix the issue (good luck with that if I'm abroad traveling). Disconnecting from the server and reconnecting again (logging in) magically fixes the issue for a while. This, together with the occasional slowness, means that I cannot count on ARC to work.
Dear Roon Team, you wrote "Our mission is to delight music lovers, and if there’s anything we could be doing better, we want to hear about it." — so you're hearing about it.
Having gone through the whole reporting process, my impression is that much of it does not apply to ARC at all, and some questions should have a “not relevant” answer (DNS servers are unlikely to cause ARC to stutter and lag).
Thanks for reaching out. When the issue next occurs, please note the exact time + date of the occurace. We’ll enable ARC diagnostics to see if there is anything we can gather for clies.
Also, to check the server side, can you please use these instructions to access your Roon Server logs, upload a set to the below link, and let us know once uploaded?
As for server logs, I have Roon installed on a Synology NAS. Unfortunately, your instructions do not show where the logs are located (the screenshot doesn’t show the full path anywhere); I tried to find them manually but was unable to.
Logs will be housed within the RoonServer folder that holds the database. This will commonly be RoonServerDB in File Station if you installed Roon using the standard Roon on NAS instructions for Synology.
This thread is now closing due to inactivity/lack of response. You can reactivate the conversation by simply submitting a new tech support request here if you require additional support.
We’ve reopened this thread to continue troubleshooting. At your convenience, please share the following information:
the current symptom you’re experiencing with regard to this original issue in ARC
whether or not you’re able to identify your RoonServer logs using the clarifications we’ve provided in our follow-up post above.
The ARC framework only shows generic timeouts with upstream services. We need to see whether the server itself is having difficulty reaching the internet around the same time to ascertain whether this is isolated to the phone.
We’ll watch for your response and proceed from there. Thanks!
The log files are quite difficult to find with these instructions. Anyway, it took some time, but I think I found them. I uploaded the log files as you instructed, I hope you can find them.
I reproduced the issue in Roon ARC on 2026-01-17 at 20:20 CET (my local time). Logs use the same time zone.
Unsurprisingly, there is absolutely nothing related to Roon ARC in the logs around that time. That’s what one would expect: as I wrote, my Roon ARC is in offline mode. I am not sure why you requested the logs and didn’t want to pursue the issue without them.
Again, to restate: Roon ARC is unusably slow when WiFi is turned off, IN OFFLINE MODE.
We’ve discussed this with our senior QA and development teams. The team is investigating some possibilities here and, as soon as that investigation is complete, we’ll be sure to follow up ASAP.
You have our apologies for the trouble here, and we’ve greatly appreciated your patience as we continue investigating this tricky issue. We’ll be in touch as soon as we can.
The R&D team has already identified the root cause and implemented a fix. These changes will be included in the next Roon ARC release. You can follow progress and availability in our Roon Software Discussion > Software Release Notes category.
Once the update is available and you’ve had a chance to install it, please let us know here. At that point, we can also discuss the possibility of providing a temporary license so you can verify whether the behavior is fully resolved.
Thanks again for your patience, and we’re hopeful this will address what you were seeing.
I wanted to say thank you for collaborating with our team to identify the issue that was impacting your Roon ARC experience. I am delighted that this has resulted in a fix.
We took the liberty of starting a 14-day free trial on your account so you can verify for yourself whether your experience is improved. You can, of course, manage this free trial as you normally would via your account page.
We’ve just pushed the updates out earlier this morning - let us know if you’re able to update all Roon devices, including your server and Arc, and let us know if things have improved for you.
Just checking in on this, were you able to update all of your Roon devices, including your Roon Server and Roon ARC. Please let us know whether things have improved on your side since we last spoke. Thanks!
