This has been an issue for several weeks. I just never bothered to reach out to the discussion boards.
I’ve had my phone heating up with DSP off and with DSP on.
I don’t suppose its related to cellular/wifi signal, as the music was downloaded to the phone in advance due to poor cell reception on the train.
A search revealed there have been several threads complaining about this, but all were closed so I couldn’t add to them, and none were solved.
There are two active RoonServers in your environment, according to our diagnostics. Do you actively migrate your account between these two machines? Which RoonServer have you synced with ARC for the iPhone 13?
There’s mainly one, running on the docker. The other is rarely used and is for debugging only. Like this time when you start to claim that you don’t support docker and I have to spin it up.
