Aidan_Gaule
(Aidan Gaule)
September 24, 2022, 10:21am
1
• Core Machine (Operating system/System info/Roon build number)**
Roon 2.0 (build 1228) on Intel i7-8559U NUC w 16GB RAM running Roon Rock.
Intel NUC → BT smart Hub 2 via Ethernet
BT Smart Hub 2->Netgear Orbi
Netgear Orbi-> Roon endpoints via wifi
various, currently iMac running Roon 2.0 on latest macOS via wifi
Issue 1
Roon arc says that it is unavailable for use outside my home network. As far as I can tell, the networking is set up correctly.
Roon
Router
Network config
Any advice would be welcome.
Issue 2
Which may be related to issue 1. I get errors connecting to Roon core that can be cleared only by logging out and back in, triggering large numbers of security alert mails. Why does Roon not recognise that I am logging in again?
Aidan Gaule
Geoff_Coupe
(Geoff Coupe)
September 24, 2022, 10:28am
2
Have you got IPv6 enabled in the BT Hub for use in your local network? If so, try turning it off. You shouldn’t be getting the need to log out and log in all the time.
See this thread:
I’m struggling to get port forwarding to connect.
My network topology is router (BT Smart Hub 2) connected via ethernet to a switch; Intel NUC running ROCK is also connected via ethernet to that switch. Router broadcasts wifi also.
I’m trying to connect using Roon running on a Windows PC which is connected via ethernet to the switch. But the Roon Mobile settings shows that it’s not connected:
[image]
It also doesn’t show the Roon Core IP (I don’t know if this is expected)?
Looking at the R…
Thanks Geoff. I will give that a try, although I’m not sure it’s the same issue as my core is showing up as connected in ARC.
Switching off ipv6 did indeed work. Thanks.
system
(system)
Closed
October 15, 2022, 10:22am
6
