What’s happening? · I'm having trouble with Roon ARC
What best describes your issue with ARC · I can't log into ARC but I can log into Roon
How can we help? · None of the above
Other options · My Roon software won't start up
Describe the issue I have switched my mobile phone from a Samsung Galaxy S24 Ultra to the S25 Ultra which runs Android 15 (instead of 14). Ever since I am not able to get Arc to run and connect to my ROCK anymore. It hangs in the first start loop without finishing. I have already tried clearing data and cache plus deinstalling the app and rebooting the phone afterwards. Still, after reinstalling the app Arc does not start properly...
Describe your network setup Fritz Box as router, Synology NAS as music library and a separate NUK for ROCK
I have had a similar issue…I ended up having to side-load ARC.
What’s happening? · I'm having trouble with Roon ARC What best describes your issue with ARC · Other How can we help? · None of the above Other options · Other Describe the issue Due to an issue reported in Aug 2024 I side loaded and ARC apk. I am now noticing that my ARC does not have new features like " listen later" . Should I delete this ARC and download a new one from the app store, or load another APK? Describe your network setup Not relevant
Thanks for your suggestion Mark. Did not help /change things anyways.
I assume it has to do with Android 15 or the S25 somehow as Arc on my DAP still connects fine.
Wonder that no one else with a S25 / Android 15 device seems to have problems though…
Rugby
(aka Daniel or Big Dan)
April 13, 2025, 4:31pm
4
I have never have had an issue with my S25/Android 15, running ARC or Roon Remote.
vadim
(Vadim)
April 14, 2025, 2:02pm
5
Hello,
Thank you for reaching Roon support, nice to see you on our comunity again!
1. Battery Optimization
Samsung’s battery management may kill background apps or restrict network access:
Go to Settings > Apps > Roon ARC > Battery
Set to “Unrestricted” (not “Optimized” or “Restricted”)
2. App Permissions
Make sure ARC has all the necessary permissions:
Settings > Apps > Roon ARC > Permissions
Allow Local Network , Storage , and Location if prompted (sometimes required for local discovery)
3. Data Usage / Network Access
Settings > Apps > Roon ARC > Mobile Data & Wi-Fi
Ensure “Allow background data usage” and “Allow data usage while Data saver is on” are enabled
4. Device Care / App Protection
Samsung’s Device Care > Memory or Security features can restrict ARC
Go to Settings > Device Care > Memory , and exclude ARC from auto-optimization
In Settings > Device Care > Battery > Background Usage Limits , remove ARC from any sleeping/deep sleeping app list
5. App Security / Secure Folder
If you’re using Samsung Knox or Secure Folder , make sure ARC is not accidentally sandboxed or blocked.
Thank you so much Vadim! I cannot tell which one of your tips made it work - but actually Arc just went alive after following steps 1-3
vadim
(Vadim)
April 14, 2025, 5:49pm
7
Hello @Chris_Kroker ,
Thank you for the update! We’re glad to hear that everything is running as expected. Enjoy listening to your music!
Kind regards,
Vadim
system
(system)
Closed
April 15, 2025, 5:49pm
8
