Roon Core sonicTransporter i5, version 2.8
Router - Linksys WHW0301 Velop Tri-Band Mesh system, Model AC2200 using 2 nodes
RoonArc did not automatically work on my system so I followed the guidance, checked UPnP was on, set up manual port forwarding but I still can’t get it to work and I’m stuck. Below is the error message, please can you help?
“external_ip”: {“actual_external_ip”:“185.225.44.148”,“router_external_ip”:null},
“upnp_autoconfig”: {“server_ip”:“192.168.1.1”,“found_upnp”:true,“error”:“<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/\” s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/\“>\n<s:Body>\n<s:Fault>\ns:Client\nUPnPError\n\n<UPnPError xmlns="urn:schemas-upnp-org:control-1-0">\n501\nPAL_UPNP_SOAP_E_ACTION_FAILED\n\n\n</s:Fault>\n</s:Body>\n</s:Envelope>\n”}
