Roon ARC not ready with FritzBox Vodafone Cable in Germany (ref#V4CD5A)
Network Setup
· My only router was provided by my ISP
ARC Status
· ARC is *Not Ready*
Roon Error Code
· “natpmp_autoconfig”: {“status”:“NotFound”}, “upnp_autoconfig”: {“status”:“NotFound”} }
Have you successfully located and enabled the UPnP or NAT-PMP settings in your router's web UI?
· I've turned UPnP/ NAT-PMP on and ARC won't connect
Select the Diagnostic Keyword or Text String
· Something else
Don't give up yet.
· I'm stuck. I'd like to create a post to ask Roon Community for help.
Roon ARC not ready, FritzBox Vodafone Cable (Germany)
FRITZ!Box 6591 Cable
MacBook Pro
Roon Error:
“ipv6_connectivity”: {“status”:“NetworkError”,“status_code”:504,“error”:“error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined”},
“ipv4_connectivity”: {“status”:“NetworkError”,“status_code”:504,“error”:“error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined”},
“external_ip”: {“actual_external_ip”:“95.hhh.iii.jjj”,“actual_external_ipv6”:“2a02:aaa:bbb:ccc:abc:acd:ade:aef”,“router_external_ip”:“null”},
“status”: “status”: MultipleNatFound
“upnp_autoconfig”: {“server_ip”:“192.168.178.1”,“found_upnp”:true}
Hi @Ingo_Koch1,
Thank you for your post. Vodafone Germany has broadly implemented Carrier-Grade Network Address Translation (CG-NAT) on their accounts, which will block port forwarding.
The simplest workaround is to install Tailscale on your RoonServer machine, the MacBook Pro. See here:
You could also configure your Fritz!Box for end-to-end IPv6 on your home network, similarly bypassing the need for IPv4 port forwarding. However, this is a more complicated step involving entering your router settings administration page and potentially other network hardware. We tend to recommend the former option, Tailscale.
