Roon ARC shuffle feature shows poor connection while using playlists (ref#T7HPE5)
When using Room Arc from my office when i try and use the shuffle feature on my preferred playlist it keeps saying poor connection? I have great wifi and home where my Nucleus One is and also here at work? I want to be able to use my Roon playlists at my office
I use Eero at home, Nucleus One is plugged directly into the Eero mesh router, at Work im on pretty fast wifi
Hey @damon.accardi,
Thanks for writing in and sharing your report!
Can you reproduce the same issue when using cellular data instead?
Which playlist specifically? And does this happy on any playlist?
Is your Nucleus connected directly into the primary router, or a node within your mesh setup? Please setup a direct ethernet connect to the primary router and let me know how the above goes. Thank you! :raised_hands:
