Windows 11 op Lenova Thinkpad Intel I7
Ethernet or Wifi same problem
NAD C368 BluOS
12000
I am using Tidal as the music service . And live radio.
I can sign in Tidal from any device including the laptop where Roon core is installed.
But when i try to sign in Tidal from Roon there is no connection. Network error.
From that moment it is also not possible to use the live radio anmore,
Also when i quit Roon and login again the problem persists.
Also trying to change the password from that moment gives a netwerk error.
After a new uninstall en instal i can use Roon and the live radio.
Also from my android Mobile device.
Then also the live radio is back.
Until the moment i again triy to login Tidal from within Roon.
Than the problem repeat.
My Android device can play e few numers in the combination Roon and Tidal.
But then suddenly also this playing stop with an network connection problem.
I also did a frehsh install of Internet with the same negative result.
At this moment i cannot use Roon in combination with Tidal on my windows 11 PC
I looked also on simular support items.
Also:
non-200 status code from Tidal, code: 400
But in that item your team make it working at a given moment.
On my android device there is also an authetication errot.
non-200 status code from Tidal: code 503
It seems that this problem now returned.
Please help.
