Has anyone used the new MBPs with either the M1 Pro or M1 Max chip as their Roon core?
How well does it work. Does the extra oomph do anything for Roon.
I know it will be faster for my photography but am still holding back from buying.
They haven’t shipped to normal customers yet. Shipping starts tomorrow and they are in demand and short supply so will likely be a while. An MBP is probably not the most cost efficient core platform, lot’s of other great choices out there. The base 14" MBP model starts at $1999.
Hi-have only ever used MBP for my core. The new chip ones are available to have now. I was just wondering if anyone had used one yet for the Core.
took one home today (16” pro max silicon). roon will not open on it
Incident Identifier: 653C49E5-57B0-4382-860D-4A595B4CBB73
CrashReporter Key: 1A07F7FB-BE8E-2E20-3197-EA1C6D8E9FA7
Hardware Model: MacBookPro18,2
Process: Roon [2751]
Path: /Applications/Roon.app/Contents/MacOS/Roon
Identifier: com.roon.Roon
Version: 1.0
Code Type: X86-64 (Native)
Role: Default
Parent Process: launchd [1]
Coalition: com.roon.Roon [1289]
Date/Time: 2021-10-26 20:29:45.2107 -0400
Launch Time: 2021-10-26 20:29:45.1846 -0400
OS Version: macOS 12.0 (21A344)
Release Type: User
Report Version: 104
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000001, 0x00007ff7ffe1baf0
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: SIGNAL 5 Trace/BPT trap: 5
Terminating Process: exc handler [2751]
Triggered by Thread: 0
Application Specific Information:
assertion failed [header->version <= kProjectSourceVersion]: runtime library is newer than runtime
(Library.cpp:99 init)
Thread 0 Crashed:
0 runtime 0x7ff7ffe1baf0 0x7ff7ffdff000 + 117488
1 runtime 0x7ff7ffe1b4c8 0x7ff7ffdff000 + 115912
2 runtime 0x7ff7ffe13350 0x7ff7ffdff000 + 82768
3 runtime 0x7ff7ffe02ac0 0x7ff7ffdff000 + 15040
4 dyld 0x204dc9000 ???
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000000 x1: 0x0000000000000003 x2: 0x000000000000003c x3: 0x000000000000002c
x4: 0x0000000000000303 x5: 0x0000000000000000 x6: 0x0000000000000000 x7: 0x0000000000000460
x8: 0x00007ff7ffe3a000 x9: 0x0000000000000000 x10: 0x0000000000000000 x11: 0x00007ff7ffe3a908
x12: 0x0000000000000000 x13: 0x0000000000000039 x14: 0x000000010d52e000 x15: 0x00007ff7ffe22828
x16: 0xffffffffffffffe1 x17: 0x00000000ffffffff x18: 0x000000030cf140ab x19: 0x00007ff7ffe302e1
x20: 0x00007ff7ffe2abe3 x21: 0x0000000000000063 x22: 0x00007ff7ffe2aba7 x23: 0x000000030cf13010
x24: 0x000000010d4da2e0 x25: 0x0000000000000248 x26: 0x0000000000000009 x27: 0x0000000204e3d1b8
x28: 0x0000000000000001 fp: 0x000000030cf12fd0 lr: 0x00007ff7ffe1bae8
sp: 0x000000030cf12fb0 pc: 0x00007ff7ffe1baf0 cpsr: 0x60000000
far: 0x000000030cf12f80 esr: 0xf2000001 (Breakpoint) brk 1
Binary Images:
0x7ff7ffdff000 - 0x7ff7ffe2efff runtime () <70e45ce2-97b7-333e-8cad-dad5f9ff28e9> /usr/libexec/rosetta/runtime
0x204dc9000 - 0x204e30fff dyld () <134d41a3-bae2-31f3-bc21-cdd091ced449> /usr/lib/dyld
Error Formulating Crash Report:
dyld_process_snapshot_get_shared_cache failed
EOF
{“app_name”:“Roon”,“timestamp”:“2021-10-26 20:29:45.00 -0400”,“app_version”:"",“slice_uuid”:“f4be97cc-44ce-3c00-a1d1-72d9cefa144d”,“build_version”:“1.0”,“platform”:0,“bundleID”:“com.roon.Roon”,“share_with_app_devs”:0,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 12.0 (21A344)”,“incident_id”:“653C49E5-57B0-4382-860D-4A595B4CBB73”,“name”:“Roon”}
“uptime” : 5000,
“procLaunch” : “2021-10-26 20:29:45.1846 -0400”,
“procRole” : “Default”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “MacBookPro18,2”,
“procStartAbsTime” : 120786094198,
“coalitionID” : 1289,
“osVersion” : {
“train” : “macOS 12.0”,
“build” : “21A344”,
“releaseType” : “User”
“captureTime” : “2021-10-26 20:29:45.2107 -0400”,
“incident” : “653C49E5-57B0-4382-860D-4A595B4CBB73”,
“bug_type” : “309”,
“pid” : 2751,
“procExitAbsTime” : 120786644023,
“translated” : true,
“cpuType” : “X86-64”,
“procName” : “Roon”,
“procPath” : “/Applications/Roon.app/Contents/MacOS/Roon”,
“bundleInfo” : {“CFBundleVersion”:“1.0”,“CFBundleIdentifier”:“com.roon.Roon”},
“storeInfo” : {“deviceIdentifierForVendor”:“B1E39157-56C2-55A0-9977-F85746E1F6C3”,“thirdParty”:true},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “com.roon.Roon”,
“crashReporterKey” : “1A07F7FB-BE8E-2E20-3197-EA1C6D8E9FA7”,
“wakeTime” : 13,
“sleepWakeUUID” : “A19C2944-A0F9-4A8C-9172-5BB57303F105”,
“sip” : “enabled”,
“isCorpse” : 1,
“exception” : {“codes”:“0x0000000000000001, 0x00007ff7ffe1baf0”,“rawCodes”:[1,140703126633200],“type”:“EXC_BREAKPOINT”,“signal”:“SIGTRAP”},
“termination” : {“flags”:0,“code”:5,“namespace”:“SIGNAL”,“indicator”:“Trace/BPT trap: 5”,“byProc”:“exc handler”,“byPid”:2751},
“asi” : {“runtime”:[“assertion failed [header->version <= kProjectSourceVersion]: runtime library is newer than runtime”,"(Library.cpp:99 init)"]},
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 0,
“threads” : [{“triggered”:true,“id”:89538,“threadState”:{“x”:[{“value”:0},{“value”:3},{“value”:60},{“value”:44},{“value”:771},{“value”:0},{“value”:0},{“value”:1120},{“value”:140703126757376},{“value”:0},{“value”:0},{“value”:140703126759688},{“value”:0},{“value”:57},{“value”:4518502400},{“value”:140703126661160},{“value”:18446744073709551585},{“value”:4294967295},{“value”:13102039211},{“value”:140703126717153},{“value”:140703126694883},{“value”:99},{“value”:140703126694823},{“value”:13102034960},{“value”:4518159072},{“value”:584},{“value”:9},{“value”:8671973816},{“value”:1}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:140703126633192},“cpsr”:{“value”:1610612736},“fp”:{“value”:13102034896},“sp”:{“value”:13102034864},“esr”:{“value”:4060086273,“description”:"(Breakpoint) brk 1"},“pc”:{“value”:140703126633200,“matchesCrashFrame”:1},“far”:{“value”:13102034816}},“frames”:[{“imageOffset”:117488,“imageIndex”:0},{“imageOffset”:115912,“imageIndex”:0},{“imageOffset”:82768,“imageIndex”:0},{“imageOffset”:15040,“imageIndex”:0},{“imageOffset”:0,“imageIndex”:1}]}],
“usedImages” : [
“source” : “P”,
“arch” : “arm64”,
“base” : 140703126515712,
“size” : 196608,
“uuid” : “70e45ce2-97b7-333e-8cad-dad5f9ff28e9”,
“path” : “/usr/libexec/rosetta/runtime”,
“name” : “runtime”
“source” : “P”,
“arch” : “x86_64”,
“base” : 8671498240,
“size” : 425984,
“uuid” : “134d41a3-bae2-31f3-bc21-cdd091ced449”,
“path” : “/usr/lib/dyld”,
“name” : “dyld”
“vmSummary” : “ReadOnly portion of Libraries: Total=800K resident=0K(0%) swapped_out_or_unallocated=800K(100%)\nWritable regions: Total=136.2M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=136.2M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nRosetta Generic 8K 2 \nRosetta IndirectBranch (reserved) 32K 1 reserved VM address space (unallocated)\nRosetta JIT 128.0M 1 \nSTACK GUARD 56.0M 1 \nStack 8176K 1 \nVM_ALLOCATE (reserved) 184K 4 reserved VM address space (unallocated)\n__DATA 80K 3 \n__DATA_CONST 48K 1 \n__LINKEDIT 240K 4 \n__TEXT 608K 2 \nmapped file 20.4M 10 \n=========== ======= ======= \nTOTAL 213.5M 30 \nTOTAL, minus reserved VM space 213.3M 30 \n”,
“legacyInfo” : {
“threadTriggered” : {
“trialInfo” : {
“rollouts” : [
“experiments” : [
“reportNotes” : [
“dyld_process_snapshot_get_shared_cache failed”
