All local.
Lampizator Atlantic TRP, USB
Core crashes.
Reinstalled/restarted multiple times. Tried 32 bit. Same problem. Roon begins to rebuild database and crashes 5 minutes in. Following initial crash of new install the Roon application will not restart–fails at startup.
Completely wiped the harddisk, reinstalled Windows, reinstalled Roon. Crashed again. Same symptoms. Something hardware related? Could someone please take a look at the attached log and provide guidance if possible? Thanks.
Do you have everything attached to the PC when you are doing these operations?
What pc are you building and have you updated the graphics drivers from the manufacturer site not windows update?
Going to update graphics drivers now. The low profile, fanless graphics card is actually the only new component that should matter (rest is fainless case, HDPlex ATX converter and Keces P8 power supply). Thank you for the advice. Will report back.
Yes, Nvidia GT 610. It seems that’s the most likely culprit. No driver update since 2017. Don’t Nvidia is really supporting it. May need to try something else.
The board is AMD with no inbuilt graphics (ASUS Crosshair VII). I do have a graphics card from an old build but it is not low profile enough to fit in the HDPlex case…
I may try to see if I can test with the old graphics card. But if the card is indeed the culprit, I will need to find another fanless solution that will play nice with Roon.
My library files are stored on a USB attached external hard drive. I had not been using Roon for several months. So the entire hard drive was a new situation for Roon. The library had been on an internal drive in the old machine. There are probably 500 new albums, mostly vinyl rips, that have been added since Roon was last used.
There are about 5500 albums in my library. So I would guess around 75,000 tracks.
The build is around an ASUS Crosshair VII Hero with an AMD Ryzen 7 3700x chip. Samsung SSD, 8 GB DDR4 RAM, a fanless GT 610 graphics card (which I ordered a replacement for hoping it was the culprit in this scenario), HDPLEX fanless case w/ HDPLEX 800w ATX/DC converter, external Keces P8 linear power supply.
Let me know if additional information would be helpful. Thank You.
Thanks for the details here. Your GPU supports the right versions of OpenGL so it should work. I think we need to see some additional details from Event Viewer. Please see these steps:
Press Win + R and type eventvwr.msc
Press OK – this should open Event Viewer window
From the left sidebar go to Windows Logs > Application
Right click on the Application subsection and pick Filter Current Log... from the context menu
