Hi Guys
I’ve been using a B M1SE for a few weeks now with Roon with USB. Great Sound / No Issues
I’ve upgrade to a B M12 and the USB connection works fine as well. Great Sound / No issues
For some reason, Roon does not recognize the M12 using an ethernet connection only
I’m using a dedicated Mac Mini for the Roon core and have both the Mac and the M12 connected to my Verizon Cable Modem/Router.
I’m happy to send screen shots and provide additional info, but I, not sure where to start.
Can anyone help
M3R
Unfortunately, I don’t think that the Bricasti M12 is a RoonReady endpoint, so you’ll need to use it (via USB) in conjunction with a network endpoint that is. The Bricasti M5 is such a device, but there are numerous lower cost options available. You could also check with Bricasti to see if they have any plans to make the M12 RoonReady.
