Google WiFi. With multiple pods throughout the house.
PS Audio Direct Stream connected to one of the pods via ethernet cable.
Library Size
Only use Roon to stream through Tidal
Spotify recognizes the DAC without any issues, however I lost my Roon connection to all devices in the house. PS Audio DirectStream and Linn Majik. I reinstall Roon but still not recognizing devices.
I would turn off your Directstream DAC, your Roon Core, and reboot all of your Google WiFi pods. Once the pods are back up, start your Roon Core and wait until it comes back up then power on your Directstream DAC.
all my devices, not only the PS Audio. My other device is a Linn Majik and is no longer recognized either. I tried to reboot everything twice without success.
Thanks Rebeka! Last night I was ready to do what you suggested and turned on the computer which asked me to update my Tidal and then voila! I do not know what eventually happened but Roon is back. Thanks for all your help !
