Roon Dropping Audio: "Waiting for Roon Core" ---> "Something's Not Right"
Nucleus+
Netgear Router (recently factory reset)
Nucleus is hardwired
Port Reopened for ARC
BluOs Nodes
Roon has been unable to complete one full song before audio drops, “Waiting for Roon Core” appears and then “Somethings Not Right” appears. It sits like that and I can start playback again. Rinse and repeat. We have had to factory reset our router recently Netgear XR7000, but I believe all the settings are proper. I’ve found a number of threads on this issue and haven’t found a solid solution.
Sounds like it could be the same issues many have now with excessive memory consumption and it simply uses all it’s resources and times out. I get the same message when “RoonAppliance” is going nuts on my NUC.
hey henrik, i don’t think that’s right. its essentially on a brand new nucleus and an brand new Apple M2 laptop. i can’t see memory being the issue. my hope/thinking is that there was some kind of internet config i might be missing after having to factory reset the router. i’m sitting here watching the roon as i work, and its constantly going back and forth between being on and offline. not even playing anything.
That might be the issue as I am receiving similar error messages from my Roon Core after it has been working for a few days.
Every time that happens the RoonServer on my Linux laptop has eaten over 13 of the available 16 gb of RAM.
A fresh reboot later and Roon works again as it should. With around 3 gb of RAM usage. But after 2 days the RAM usage is back up to 13.2 gb again.
Did some more testing - has been running while playing thru the MB Pro Laptop without dropping for over an hour. Have activity monitor open as well, hovering at about 617mb give or take the whole time. Would love to solve this.
Wondering if there’s anyone else experiencing this or if there is a fix?
Have updated Roon via the app (little purple pop up) and still can’t make it thru a single song without a drop out. Would love help in getting this solved - is @support monitoring? How can I fix this issue?
