I am looking for Roon DSP Engine - Parametric equalizer - Settings for Astell & Kern Pathfinder.
For my Meze Rai Penta I have found the settings here:
But Astell & Kern Pathfinder is not on the list
THX for any suggestions.
Torben
Torben
Likey not been tested or a common set of phones, just google to see if you can find any posted elsewhere
I did get some help from a very nice guy:
But “only” designed for 44.1kHz sample rate. But I mostly listen to high resolution tracks.
Torben
Roon will take care of that by upsampling the filter to match the source rate.
