The more I dig into Roon DSP, the better it gets, but SRC is still a bit of a mystery to me.
I cannot fully grasp how the Roon does SRC, most likely because of my lack of knowledge of SRC in general.
From Roon Knowledge Base:
“Roon’s sample rate converters use fully synchronous, polyphase interpolation. Most are “apodizing”, and they roll off slowly to minimize ringing. Both minimum phase and linear phase options are available.”
I understand that there are two basic ways to do SRC: converting to an analog continuous signal, then re-sampling at the new rate, or calculating the values of the new samples directly from the old samples.
So it looks the first method is DA->AD, the second is DD conversion?
Which one of those two methods is used by Roon DSP?
