Ethernet using ubnt hardware
RPI/hifiberry ethernet
i have an endpoint using rpi3/hifiberry amp (gym/192.168.1.158) which has worked properly in the past. it’s now not showing up in the list of audio endpoints (i’ve rebooted core and endpoint, checked roonbridge is running on endpoint)
if i settings->about the endpoint is listed, i can also see the airplay (shairportsync) endpoint in the settings->audio although i haven’t enabled it
not clear what is wrong…all other similar endpoints rpi3/hifiberry(6) and other roon ready(7) work fine
Can you please check the HAT on the Pi? As @Bart_Koekkoek mentioned, if the Pi is not detecting the DAC properly, I believe it doesn’t show up under Audio. Have you made any physical changes to the setup from when it was working vs now?
you can close this (not clear what was wrong most likely flash corruption) …i ended up re flashing the endpoint and adding back roon and airplay … all is well now
