Oh @Frucoboti,
just test Roon and dig deep into it!
Enjoy the stories about the artists and their albums, use the cross references to discover new music, enjoy karaoke with the lyrics Roon provides, discover the abilities you have with Roon DSP and all the Roon extensions. In Any case you also must get a trail of Qobuz or Tidal instead of Spotify to make full use of Roon.
And then please come back and revise your statement
Album art and other metadata will never show in the HEOS now playing screen.
Thatās a HEOS deficiency rather than ROON
I use the Roon Display to a Chromecast hooked into my TV if I want a display - way better! (You could also connect to your TVās browser or plug the Chromecast into the Marantz HDMI and configure audio out to be separate from the TV display - I think.)
Have you found the Displays under Settings ā Displays?
Hereās some help:
And this is what you will see on the screen :
Volumio isnāt bad but really doesnāt compare to ROON once you explore all the possibilities (Disclaimer : This is my own opinion. I have no financial or other relationship with ROON). Enjoy your Trial!).
RHEOS becomes even better if you have a collection of players. The multizone grouping is very useful if you ever choose a portable speaker or another room with a Denon/Marantz amp.
And please remember RHEOS (and ROON EXTENSION-MANGER) are FREE and OPEN-SOURCE You can run them on virtually any Linux box (I run mine on various models but I have the ROON server and RHEOS installed together on one NUC and this is a really nice set up.) (Sorry Dr. CWO).
Bless you Sir, thank you so much for your efforts, I have had a look and alas I donāt think this is something I can implement. I have the Marantz NR1200 AMP. It has Heos, But everything I have is Macā¦
Ah - it wonāt work with the extensions manager but there is a way the binaries may be compiled for a Mac - but you would be the ātesterā as I have no access.
If you are interested pm me and we can discuss how I nay be able to explore this for you.
As I said, I am currently now subscriber to Qobuz, Tidal Hi-Fi Plus, Apple Music and Spotify. So I can play from different sources. So testing now Roon with Qobuz and Tidal.
Why? because I can stream to my Marantz with HEOS APP from Tidal, but no way from Qobuz (or use Audirvana from the iMac)
I have seen that Roon supports streaming radio stations, but, with MP3 quality??? but no Spotify?? because itās low fi? I donāt understandā¦
Then why Audirvana can show the cover, artist, song, and remaining time? I suppose (but I donāt know if it is true) that uses HEOS to stream to Marantzā¦
No, but I have purchased the TV:Remote Apple TV app
@peter_richardson, thank you very much for this nice extension. After overcoming the first hurdles which you solved quickly for me, it powers my soundbar which now sounds very much better than with Airplay.
@peter_richardson - for the docker install, is there a volume mapping available so the settings can be exposed in the docker host for a backup process to save across updates (docker refresh) or is it not a big deal (I tested a forced reset of the docker image and all the devices showed up again, however, the quality defaulted back to CD-Quality ) [yeah, I know, first world problems having to change a handful of devices to hi-res ]
BTW everyone, I have been using this tool for well over 2 months - hands down, best app ever to get the heos ecosystem to be hi-res!
My word Peter, what an amazing extension for Roon and Marantz you have developed!
All your help has been legendary, and all working good on my mac!
Volume control stopped working on Roon to Marantz, reset, rebooted and all ok again, but loving it so far!
Iāve got this extension running both on a Synology Diskstation (using Docker) and on Windows 11 (gh install, running within Node). For the former the Roon core is running on the Diskstation, for the latter itās running on Windows. I donāt have them running in both places at once.
Unfortunately neither installation is able to find my Marantz SR7012. I have it in HEOS mode, itās on the same subnet, I just have the usual firewalls (e.g. Windows Firewall) and have allowed access. Iāve enabled Squeezebox support. Everything uses a wired connection and the AVR is signed into my HEOS account. The HEOS app and BubbleUPnP can find it and play through it.
The extension runs ok, it just canāt find any HEOS devices. Iāve added the IP of the AVR and also of the host, didnāt help. I just get āHEOS connection failedā.
Iāve not seen anyone else having trouble. Iām reasonably savvy but Iām pretty much out of things to try. Part of me thinks my Netgear Orbi might be to blame, but BubbleUPnP works.
Thanks for the quick reply Peter. I canāt see a way to PM you, perhaps because Iām a n00b. However thereās nothing in the logs Iāve found thatās sensitive.
For the Windows installation (which is the latest version) there are no log files. The command window just says:
STARTING UP - WINDOWS
192.168.2.29,Windows_NT,desktop-sean,win32,x64
NO CONNECTION Heos Connection failed Heos Connection failed
On the NAS the log for the docker image says ā192.168.2.248,Linux,rheos-roon-extension-rheos2,linux,x64ā and then a bunch of āHEOS connection failedā messages. Itās the docker image taken yesterday from Docker
Please let me know if thereās something else I should look at or if thereās a way to enable logging.
Thanks for the help, your extension is the difference between me using Roon or sticking with the clunky (to me) BubbleUPnP UI.
