Roon Server (Ubuntu Server 18.04/KVM i5-4590T 4GB 20GB SSD/build 505)
wired TP-Link TL-SG116E switch / 2x media converters TP-Link MC100CM
MSB DAC IV USB with RoonBridge on HummingBoard/Armbian - kernel 4.19
If I reboot the RoonBridge, the enabled audio devices are forgotten and I need to reenable them. This happens for ALL configured devices, they are all forgotten.
No problems if I restart just the RoonBridge service (systemctl restart RoonBridge). The devices are still enabled after the restart.
I checked the logs trying to find a difference and I noticed that the machine_id in RAATServer.log changes after a system reboot while it doesn’t if just restart the service (as expected).
Another RoonBridge installation, Debian Stretch installed from scratch, following Debian ARM installation instruction, doesn’t exhibit the same behavior and the devices are still enabled after rebooting. A log check shows that, in this case, the machine_id is preserved across reboots. The kernel here is 4.18, from Stretch backports.
Now, the questions are:
- Is the machine_id change which causes the problems, as the RoonBridge is considered a new device after the reboot?
- What the machine_id calculation depends on? If you could share some details on that I can go into deeper investigation about the cause of the problem.
Marcello
