Roon is frozen with possible connection issue with Bluesound Powernode (ref#IJB8HQ)
· Ethernet
Please try rebooting your router.
· No, I'm still having trouble
· Blusound Powernode v 2.0
Roon is "frozen" - possible connection issue with Blusound Powernode
I cannot see the fiberoptic model make or model. The router is a Zyxel c3510xz. No range extenders are used
This could be a communication issue between Roon and your Powernode, have you tried closing Roon and power cycling your Powernode?
I agree that it seems to be a communication issue b/w Roon and Powernode. I’ve tried powering down w/ Roon closed and that did not do the trick.
Are you able to do a shutdown of your router? If yes, maybe try a thirty minute downtime and then start powering up Roon and then the Powernode. You may need to re-configure the Powernode in Roons audio settings.
Before you do this, does the Powernode have a full blue light?
Yes the powernode indicates a full blue light. I can use the powernode on the network using separate apps (e.g. Tidal) with no problem. That’s why I suspect it is roon and the powernode not getting along for some reason.
I did try rebooting my router (but not for 30 minutes - more like 1 minute).
Hi @tessington,
Thanks for writing in to let us know about this issue. I think the next step here is to enable some diagnostics on your account so our technical staff can get some more insight into what’s going on here.
Hi Daniel - fortunately the situation is resolved. I re-booted everything that could be re-booted: the modem, router, powernode, and server (I think the latter is what did the trick). Once back on, Roon was unfrozen and I could once again add and remove tracks to the queue.
I’m glad that Roon is working for you again. Enjoy!
