Antipodes K40
Ethernet direct into K40
Ethernet from K40 directly into Weiss DAC 502, over to a Luxman 590axii
3,516 tracks
Roon won’t play. The line where it shows the timeline for the music is just going back and forth with a blue line. I have no idea what’s happening. Everything worked yesterday and now it no longer works. I tried closing out Roon and restarting it but the problem persists. I’m running an Antipodes K40 as my music server with an ethernet connection to my DAC. I uploaded a screenshot below. The blue line, if it was a video, would be pulsing left to right and back again. Kind of ping ponging back and forth.
Thanks.
Here is another screen shot saying that DSP volume - a digital volume adjustment has been applied to the audio stream. How did that happen and how do I change it back?
I should also add that when I try and go into device setup on Roon for the Weiss DAC 502, the Roon symbol keeps “spinning”. It’s been going on now for more than 15 minutes. As such, I have no way of accessing any audio settings for the Weiss through Roon. Also, I confirmed that nothing has changed in audio settings on the DAC itself. This seems to be a Roon issue.
