TP Link Archer VR2800, Ethernet
Devialet Pro Expert 440/Naim Qube/Naim Atom
The lovely shiny new version of Roon with Live Radio has completely trashed ALL my previously saved radio stations. Thanks guys. BBC radio is NOT streamable from the BBC website (unless you use BBC Sounds)
The question is: how do I interrogate my Roon backups to retrieve the actual URLs that I have been using for HD BBC radio streaming?
Or does anybody have a good data source for this stuff?
I have just checked in more detail and it is specific to Radio 2 and Radio 3. The other BBC stations appear to work OK. BBC R2 & R3 show up in ‘My Live Radio’ but they no longer have the URLs that i saved them with. The URLs appear to have been overwritten. When I select BBC R2 or R3 I get ‘Unable to play station. Its address may have changed, or it may be temporarily available’
Are you located in the UK? From what I recall the BBC stations are limited to just the UK as @BrianW mentioned. Since manually adding the URLs you found back in, do they play as expected?
