Update. Also loses connection:
When Rpi/Ropieee goes to screensaver
Same problem with an RPi3b and a Beresford DAC via USB
Intel NUC with ROON optimised core kit version1.8 build 756
All wired with cat 5
Pro-ject pre box RS Digital driven (USB connection) by Raspberry Pi 4 and RopieeeXL 1.7 build 571
Pre update to 1.8 this worked faultlessly. The Pro-ject box is switched off overnight, then switched on before opening the Roon controller on an iPad. Since the update, the Pro-ject box does not appear as a zone until the ROON NUC is rebooted. After that, all works fine. Rebooting the controller on the iPad and rebooting Ropiee has no effect.
