Lenovo laptop L4 (Win10 pro / i7 16Gb 64 / Roon build 710 64bit)
TP-Link OnHub, joined to KEF speakers with ethernet cable and by wifi to laptop
Kef LS50W speakers, connected by wire to TP-Link
I just switched the Roon core from an aging Surface Pro4 to this new laptop with same network setup.
I was having periodical connection issue with Surface Pro, same “Roon lost control of audio device”, which I would fix by restarting Roon, and/or the speakers and/or turning the TP-Link off and back on, not always successfully.
I was hoping the problem was because of old Surface Pro but no such luck: I haven’t been able to run Roon from new Lenovo at all yet: I get the “Roon lost control…” every way I tried: playing music from Tidal, or from music stored in Lenovo.
I tried resetting the KEF, no progress.
The speakers show up on Roon, and are turned on when starting a new song, but just don’t play.
The speakers work normally with the KEF app on tablet and phone using the same wifi network.
Help! Thanks,
Bernard
