Everything wired
NAD C390DD with BluOS MDC module
After install of Roon 1.8, I’m getting “Roon lost control of audio device” errors playing Tidal tracks to my NAD C390DD amp. I do not get errors on other endpoints.
Here is an extract from the Rock log at the time of error (Den is my C390DD):
[Den] [zoneplayer] Playing: http://ab-pr-cf.audio.tidal.com/3001d6bc860d065be525d92a794d4944_39.flac
03/09 20:59:23 Trace: [tidal/http] GET https://api.tidal.com/v1/tracks/172239583?countryCode=CA => Success
03/09 20:59:23 Info: [Den] [zoneplayer] Queueing: http://ab-pr-cf.audio.tidal.com/ea171a8013c81754486ed5a46aa85ebc_39.flac
03/09 20:59:23 Trace: [streamingmediafile] immediate read of http://ab-pr-cf.audio.tidal.com/3001d6bc860d065be525d92a794d4944_39.flac at 262144 length=57900491
03/09 20:59:23 Trace: [streamingmediafile] immediate read of http://ab-pr-cf.audio.tidal.com/ea171a8013c81754486ed5a46aa85ebc_39.flac at 262144 length=31222697
03/09 20:59:24 Info: [Den] [zoneplayer] Open Result (Playing):Result[Status=Success]
03/09 20:59:24 Info: [Den] [zoneplayer] Starting playback
03/09 20:59:24 Trace: [streamingmediafile] immediate read of http://ab-pr-cf.audio.tidal.com/3001d6bc860d065be525d92a794d4944_39.flac at 524288 length=57900491
03/09 20:59:24 Info: [audio/env] [env000022] All streams were disposed
03/09 20:59:24 Trace: [convolution] resampled 131072 samples to 285689 samples using linear_phase_precise (44100 => 96000)
03/09 20:59:24 Info: [audio/env] [env000023] All streams were disposed
03/09 20:59:24 Info: [audio/env] [env000024] All streams were disposed
03/09 20:59:24 Trace: [convolution] normalized norm=0.45937578704471294 before 0.0026904338356947277 after 0.0026904338357112874
03/09 20:59:24 Debug: [convolution] adjusted filter length from 285689 to 285686 since filter had trailing zeroes
03/09 20:59:24 Debug: [convolution] performing convolution with 2 paths
03/09 20:59:24 Trace: [Den] [zoneplayer/raat] StartStream Sooloos.Broker.Transport.RaatZonePlayer+Endpoint: StreamFormat(channels=2, bitspersample=24, samplerate=96000, isdts=False, mqa_core=96000) => StreamFormat(channels=2, bitspersample=24, samplerate=96000, isdts=False, mqa_core=96000) streamid=889679992
03/09 20:59:24 Trace: [NAD C390 @ 10.22.1.15:43995] [raatclient] SENT [14]{“request”:“setup”,“format”:{“sample_type”:“pcm”,“sample_rate”:96000,“bits_per_sample”:24,“channels”:2,“sample_subtype”:“mqa_core”,“mqa_original_sample_rate”:96000}}
03/09 20:59:24 Info: [zone Den] OnPlayFeedback Playing
03/09 20:59:24 Trace: [Den] [Enhanced, 24/48 MQA TIDAL FLAC => 24/96 MQA] [100% buf] [PLAYING @ 0:00] Four Paths of Light, Pt. 3 - Pat Metheny
03/09 20:59:24 Trace: [musicpowerstate] music is playing, preventing idle sleep
03/09 20:59:24 Info: [Den] [zoneplayer] Open result (Queueing): Result[Status=Success]
03/09 20:59:24 Trace: [prebuffer] ready 163200/480000 (34%) @ 0/330 sec
03/09 20:59:24 Trace: [streamingmediafile] immediate read of http://ab-pr-cf.audio.tidal.com/3001d6bc860d065be525d92a794d4944_39.flac at 786432 length=57900491 03/09 20:59:24 Trace: [streamingmediafile] immediate read of http://ab-pr-cf.audio.tidal.com/3001d6bc860d065be525d92a794d4944_39.flac at 1048576 length=57900491 03/09 20:59:24 Trace: [NAD C390 @ 10.22.1.15:43995] [raatclient] GOT [14] {“status”:“Lost”,“reason”:[]} 03/09 20:59:24 Trace: [Den] [zoneplayer/raat] Got ‘lost’ response 03/09 20:59:24 Trace: [Den] [zoneplayer/raat] lost endpoint. stopping stream
03/09 20:59:24 Info: sleep 0ms after flush
03/09 20:59:24 Warn: [zone Den] Track Stopped Due to LostEndpoint
03/09 20:59:24 Info: [audio/env] [zoneplayer → stream → endpoint] All streams were disposed
03/09 20:59:24 Info: [audio/env] [zoneplayer → stream] All streams were disposed
03/09 20:59:24 Info: [zone Den] OnPlayFeedback StoppedLostEndpoint
03/09 20:59:24 Trace: [zone Den] Suspend
03/09 20:59:24 Info: [zone Den] Canceling Pending Sleep
03/09 20:59:24 Trace: [Den] [Enhanced, 24/48 MQA TIDAL FLAC => 24/96 MQA] [100% buf] [STOPPED @ 0:00] Four Paths of Light, Pt. 3 - Pat Metheny
03/09 20:59:24 Info: [audio/env] [zoneplayer] All streams were disposed
I cannot thank you enough for your patience and for following up with all the details that you have. I am sorry it’s been taking us this long to get back to you
Are you still getting errors with your NAD C390DD? Did NAD or BlueSound get a chance to reply?
@beka , BlueSound advised that if Roon and NAD were communicating I should wait for NAD to resolve. My NAD amp is no longer being sold, so I’m relying on you to work with (i.e. prod) them . My Roon system did an update yesterday, but it did not solve the issue with the NAD C390DD disconnecting when asked to play MQA tracks from Tidal.
