I have no problem with Dirac for room correction, since it serves a clear purpose. It just imposes limitations and I feel there are better alternatives (explained earlier), but if your DAC cannot do anything higher than 192k PCM you don’t have much problem with Dirac either. It would be best to run Dirac at highest rate it supports, nowadays 192k, so upsample everything to 192/32 in HQPlayer before sending it to Dirac. However, it imposes similar limitations to HQPlayer as JPlay, hiding information about the DAC.
I run my DACs at DSD256 or DSD512 and also want room correction for DSD content without converting to low rate PCM so that rules out Dirac on signal path (except if the filter is extracted and run inside HQPlayer instead).
JPlay in my opinion doesn’t serve any purpose, causes problems and hides necessary information from HQPlayer so it cannot perform at it’s best. It hides information and limits functionality.
For HQPlayer to perform at it’s best it needs to have as direct and low level access to the DAC as possible. For example, if you boot my NAA image, it can get that regardless if you run HQPlayer on Windows, Mac or Linux.
