I’ve configured Dirac Audio Processor to 96khz.
Also enabled event mode and the flag that says handle device with misreported capabilities (don’t have access to the configuration screen anymore, see below).
Since then Roon is getting stuck on Enabling Dirac WASAPI:
I tried reverting Dirac to 44.1khz (which worked earlier), but couldn’t revert the device settings (event mode, handle…) on roon due to the stuck nature. Tried uninstalling roon (including removing settings) and reinstalling - same.
Thank you for the report here! Since you are having an issue with enabling the DIRAC zone, I would suggest trying to perform a RAATServer refresh. You can generate a new RAATServer instance on your device by following these instructions, but please be aware that this will reset your Roon Settings → Audio Tab to factory settings and I would advise making a backup of any custom DSP settings you have:
