When I double click the Roon icon (Circle with vertical lines to right), the icon vertical lines keep moving but it does not find anything to connect to.
The Ethernet switches are not managed. Tried disabling the firewall, modem. Tried rebooting the Nucleus+ server several times. Roon is still not connecting (i.e. finding the core)
My Home edition of Windows 10 does not support Remote Desktop. I have reinstalled Windows. With respect to my home ethernet network, I have unplugged my modem/router, unplugged my Vortexbox server, Roon Nucleus+ server, microrendu, NAD M50.2 HoloAudio Kitsune DAC and replugged them in and booted them up. I trouble shot my network connections & network adpater. Roon software is still unable to connect with my Roon Nucleus + server. This is frustrating. Do you have any other ideas to solve this problem?
I tried re-installing the Roon software on my Dell XPS-8700 desktop computer to try to solve the problem but it did not help. An IT guy helping me suggested that I uninstall Roon software first. However when we attempt to uninstall Roon it gives us two boxes to check off. One uninstalls Roon applications. The other box uninstalls settings & databases. Can you advise me as to which boxes to check off?
By the way, I am having the same problem of Roon not connecting to my core Roon Nucleus+ server when I try to use the Roon app on may Apple iPhone 7.
Roon is still not connecting after I uninstalled and re-installed Roon. From the Roon community I can see that I am not the only one having this problem. I need help.
I did figure out what you were asking for but I am having trouble adding the screen shots because for some reason the are not jpgs & therefore can’t be attached to this message .I will describe the screen shots. When I click on the Roon icon a screen comes up to connect to the Roon Core but when I try to do so the round circle keeps moving but nothing happens.
Hello @Greg_Johnson, and thanks for trying to get those images over to me. Are you saying you can’t copy and paste them into your response here? Can you add them to a google drive or dropbox and send me a link? Also, I think my last post got marked as a solution accidentally, so I removed it.
