My original setup that worked fine was connecting my Roon Nucleus from an Ethernet connection on my router directly to my Roon nucleus
I have moved addresses and am no longer able to connect my router via Ethernet directly to my Roon Nucleus. I am now connecting it via Ethernet on the nucleus thru a Ethernet to USB converter which does not seem to work. Is this not supported and the only way to connect is a direct Ethernet to Ethernet connection?
