Hi,
I have the setup below but have an issue with the volume control in Roon. I can slide the volume up and down but the volume does not always change. This is intermittent and will happen about 1 in 5 attempts. If I use the plus/minus buttons in the app I get the same issue.
What version of Roon you are running - 1.4 build 310
What operating system you are running - Windows 10 64 bit
What is Roon server running on – Intel Core i7 NUC 16gb / 512 SSD / Windows 10
Basic information about the device you’re using – Microsoft Surface Pro 4 Core i7 / 16GB RAM / 512 SSD
Describe where your music is stored – Synology NAS connected via Gbit switch
Let us know your collection size – Around 36000 tracks
What is your end point: NAIM MuSo
