Ethernet cable to Netgear Orbi
Ethernet cable to LS50W. LS50W is active speaker and connected to an electric noise filter extension cord
Hi! Thank you so much for the support!
Well, I hear exactly same scratchy noise at exactly same point of a song. This is only the one example.
In the video, the melody G#-D-E-B-C# repeats twice. Pay attention to the last C# note. There’s scratchy, vibrating noise follows.
I can repeat this song and I hear exactly same nose at same point.
I hear this kind of scratchy/vibrating noise from most of the songs I play but the length/quality of the noise itself is different from the song to song. However, I can reproduce same noise at same song at the same point.
When I play directly from my phone’s Spotfy to the LS50W using wifi, I don’t hear this noise at all.Therefore, I suspect it’s computer/Roon/soundboard issue.
I re-installed Windows/Roon. Still exactly same (probably hardware origin then?)
It looks like the example link you sent is broken, so if you could upload it once more that would be helpful.
As for this issue, can you confirm if it occurs on any other zones, such as your PC’s System Output zone? Does it impact both local and streaming content?
I had a similar experience and unfortunately it was precursor to my ls50w’s breaking completely and needing to be returned
How far are you in to the warranty? Might be worth looking into
I tried;
Roon with local library album -> Parametric EQ - > wired to LS50w YES noise
Roon with Tidal version -> Parametric EQ - > wired to LS50w YES noise
Roon with local library album -> No EQ -> wired to LS50w NO
Roon with Tidal version -> No EQ -> wired to LS50w NO
Roon -> Parametric EQ - > wifi BluSound Flex NO
Roon -> Parametric EQ - > system out NO
It only happens in combo of Roon’s EQ + LS50W, whatever the version I play. The noise sounds almost like speaker cracking.
Possible because double DSP? LS50W do have DSP built-in.
Hi John
That was it!! You fixed it magically.
Even though the signal pass light never light up red, adding headroom did fix this noise.
Amazing support, John.
Thank you so much.
