When I click play of any Qobuz or Tidal song, Roon skip it to next and does not play any. I reset router, log out Tidal and Qobuz and make another sync, still problem occur.
Thank you for reply. The problem solved after pc reset, it is not first time that it occured, but still not common issue. Roon server is used as shell core in very stripped Win 10, but it giving best sound option, so worth to test new stripped os versions.
