Looking at the Roon logs, I’m not seeing any Roon-specific problems. No errors that really stand out. Are you able to remove the drive and run some tests on it? It’s possible the drive is failing and that’s why it is disappearing.
Thank you
I do not have a way to test.
I will reinstall if it runs and , then I suspect a drive issue as it has to essentially be forced and then randomly works.
I can warranty it out.
Can I delete the Log.zip safely? I appears to be a duplicate.
Yes, you can delete the log.zip file. If there’s anything else we can help with in the future here just let us know!
