· WiFi
· RoonReady
· No, it does not show up there
· Only one output type is affected while the other output type works as expected
· Audio device: Node 2i, connected through the wifi
Hello, I use Roon with a Macbook Pro as a server, and a Node 2i to play the music. I have two recurring issues:
1. Very often, my Roon remote app does not connect immediately to the Roon server. It takes a lot of time (from a few minutes to half an hour) for it to connect.
2. While playing on the Node 2i, sometimes the music stops because Roon loses the connection to the Node 2i, and the Node audio zone disappears. The Node audio zone usually comes back quickly, so I can restart the music, but that issue interrupts the music very frequently.
Internet: BT hub (UK). All components are linked through Wifi. Server: MacBook Pro 2017 (i5, 3.1GHz, RAM 8GB). DAC: Node 2i
