Roon Core Zen Min Innuos Mk 2 Remote Opportunity Blu Ray 205 DVD player
Blue ray and Zen mini connected via ethernet.
HDMI connection
keeps cutting out sporadically and cannot rediscover
HDMI connection
Hi @Dr_Arjun_Rao,
Just to confirm, is it the connection from your remote device that is cutting out or is it the connection to the audio endpoint?
Can you confirm what kind of remotes you are using and how they’re connected to the network?
Dylan seems to be working now since I did a software upgrade on the Roon core ( Zen Mini MK II). Please refer to my query regarding the iOS remotes. Works on MacBook and iPhone but not mini- iPad. Thx.
