Roon Remote IOS control using IP? [Resolved]
Is their a way to connect the Roon remote for IOS via an IP address rather via a wifi connection? My computer/server is running wired to the network and not using wifi. Thank you!
@Damon_Roger What do you mean? iOS needs a form of connection regardless, IP is irrelevant if you do not have some type of connection to your network.
Can you be more specific? :slight_smile:
Yeah, I just got my head wrapped around that and somehow got it working. Thanks for the reply!
I am glad you got it :slight_smile:
