Roon Remote Loses Connection to Qobuz
MacBook Pro late 2013
2 GHz Intel i7
8GB
256GB
Mac OS 11.7.10 (Big Sur)
Netgear CAX30
WiFi connection to core
No VPN
Oppo UDP-205 (WiFi)
iPad Air (5th gen) (remote)
Approx. 13,000 tracks
Qobuz
Purchased the Netgear modem/router less than one month ago. Not using the “smart connect” feature. My iPad Air (remote) loses connection, and I get a message about Qobuz slow connectivity and later failed to connect to Qobuz. This happens on 44/16 files. Playing songs from my library on a WD HD seems to work okay. Signed out of Qobuz. Rebooted core, and signed back in, but error persisted. Worked okay previously, about 5 days ago.
Any help is appreciated. Thank you.
Note: since I posted this, I went into Netgear router settings and disabled IPv6 firewall. Have not tested yet.
I was able to resolve this by creating a separate wireless network with my Apple time capsule in bridge mode. This network is used only for the core, the remote, and the endpoint. Seems like a temporary solution but it works.
