Network ASUS RT-AX88U Wired to MAC M1 (Wireless to other remotes)
Connected Devices. USB
Library Size = 11730 tracks
Roon remote on Mac M1 Mini suddenly won’t load. The start up screen appears but it doesn’t get as far as loading the the central portion of the display before the Apple wheel appears. The Force Quit window has the Roon app as not responding
Roon remotes on IOS, Android and Windows are all working fine
Any ideas before I go to the uninstall/reinstall step. Have sent force quit logs off. Any use to you?
I’d try rebooting the core too. Also, did you upgrade your Mini to 12.3 yesterday? If so, I’ve had Roon client crash a couple of times since then, and just after I upgraded it refused to load and needed force quitting. I haven’t reported it, as it seems ok now, but there may be some sort of issue with 12.3.
OK, so try the core reboot. If that doesn’t help, download a fresh copy of Roon and replace your current version. If that also fails, you could try a full reinstall or wait for support to get back to you.
