Synology DSM 1.6.7-15284 (a port of the platform, running on ESXi)
Roon Server 1.8 build 756
Remote Roon 1.8 build 756 running on Android 10
TEXT GOES HERE
FritzBox 7581 on WiFi, server and BlueSound streamer are connected over Ethernet.
TEXT GOES HERE
BlueSound Node2i
TEXT GOES HERE
Remote hangs in “R O O N” splash screen, need to close the app once or twice then it will work, fortunately it (still) works then. Is like it to not hang in splash screen!
TEXT GOES HERE
Apologies for the delay! Our team’s queue is longer than typical at the moment, but we’re working to get back to everyone as quickly as we can.
How often does this occur? Are there any patterns that you’ve noticed that lead to this behavior? Does this happen while the app is actively in use or after it’s been idle for some time?
