Roon server was running fine. Then stopped playing. I have rebooted several times, also power cycled, and Roon will not power up. No sign of power. Tried various known good power sources.
The support team will be back on Monday. Fellow user here.
Is the device the Nucleus sitting on, hot? You could Move the Nucleus, connect a keyboard and monitor and see what it displays (or not displays) on the monitor.
Please try to do what @Rugby advised: connect the Display and try to turn it on. Do you see anything on display ? If not please try to switch the power adaptor and try again. If it still does not show anything on the display and does not give any signs of life please create a new support ticket and select option “I have a problem with hardware”. This option will allow you to create a ticket to RMA team.
This thread is now closing due to lack of response/inactivity. If you require further troubleshooting, you can reactivate the discussion by simply submitting a new tech support request and referencing this thread URL (select “other”). Please provide the information requested in the posts above to expedite our efforts to assist.
