NUC8i7BEK.
Orbi 50 RB router.
Hello I am in the middle of installation of Roon Lab with NUC 8i7. I used the steps on the web and downloaded the ROCK software there.
It looked all good and I installed missing codec by placing “ffmpeg” file it into the rock/data/codecs folder.
ROCK shows that:
- Operating System is OK and stable
- Roon Database & Settings are OK
BUT
- Roon Server Software is NOT Running
and If I press the “Start” I got this message
Restart Error - Roon Server could not be successfully restarted. Please try rebooting, or contact support.
I did a new setup an got the same message.
Can you please help
