Roon Setting Library>Background audio analysis speed query
The setting in Library > Background audio analysis speed is set to 10 cores as I have a 12 core Intel NUC (overkill, I know). My analysis displays Analyzing: 29 / 32 and never changes as spinner never stops as it appears my server is stuck on the last 3 pieces of analysis. What is happening?
Hey there, just another user suggesting to try and reboot your Roon server machine to fix your issue.
If it persists check Settings - Library - Skipped files and Library maintenance to remedy possibly corrupted files.
