Roon skipping to next track, part way through playing current track, maybe every 10th track
MacOS Mojave running on a 2017 iMac, Roon database on the internal flash storage.
Music library on directly attached 5 disk RAID array.
SignalPath Quality = Lossless
Elements:
Source Format=Alac 192000/24/2 BitRate=4022 Quality=Lossless
Raat Device=xCORE USB Audio 2.0
Output OutputType=Local_ExclusiveMode_CoreAudio Quality=Lossless SubType= Model=xCORE USB Audio 2.0
Been having this problem for a while but hadn’t debugged it.
This time grabbed the log file.
It really shouldn’t be a performance problem, but log seems to say it is?
08/28 10:35:17 Warn: [ui/slowness] widget newwaveform(2392) took 218ms to _Update
08/28 10:35:17 Debug: GMS: done saving nav stack
08/28 10:35:18 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [100% buf] [PLAYING @ 0:01/6:58] Mr. P.C. - John Coltrane
08/28 10:35:19 Trace: [analysis] analysis completed in 2597ms for 224s of ALAC 44.1kHz 16bit audio. loudness=-15.71410088414LUFS dbTP=-0.000265076360379619 noisestartms=130 noiseendms=218686 isdts=False mqa=0 for track 23962674 url=/Volumes/macbt/itunes/music/John Coltrane/Giant Steps/08 Giant Steps (Alternate Take).m4a
08/28 10:35:19 Trace: [library] finished with 1 dirty tracks 1 dirty albums 1 dirty performers 1 dirty works 1 dirty performances 0 clumping tracks, 0 clumping auxfiles 0 compute tracks, 0 deleted tracks, 1 tracks to (re)load, 0 tracks to retain, 0 auxfiles to (re)load, 0 auxfiles to retain, and 5 changed objects
08/28 10:35:19 Trace: [dbperf] flush 4956 bytes, 2 ops in 7 ms (cumulative 498173780 bytes, 549190 ops in 358332 ms)
08/28 10:35:19 Trace: [library] endmutation in 95ms
08/28 10:35:19 Info: [audiodevice] updating analysis info for next track because analysis finished
08/28 10:35:19 Info: [zoneplayer/signal] update playparams to gain=0dB peak=dB basems=0 noisestartms=78 noiseendms=414674
08/28 10:35:19 Info: [zoneplayer/signal] update playparams to gain=0dB peak=dB basems=0 noisestartms=130 noiseendms=218686
08/28 10:35:21 Info: [stats] 12174mb Virtual, 4035mb Physical, 2372mb Managed, 94 Threads,  FDs
08/28 10:35:23 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [100% buf] [PLAYING @ 0:05/6:58] Mr. P.C. - John Coltrane
08/28 10:35:28 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [100% buf] [PLAYING @ 0:11/6:58] Mr. P.C. - John Coltrane
08/28 10:35:32 Trace: [Holo] [zoneplayer/raat] sync xCORE USB Audio 2.0 : realtime=2970882976477 rtt=500us offset=-59490794023us delta=-313us drift=9787us in 1070.191s (9.145ppm, 32.923ms/hr)
08/28 10:35:33 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [100% buf] [PLAYING @ 0:16/6:58] Mr. P.C. - John Coltrane
08/28 10:35:37 Info: [stats] 12174mb Virtual, 4037mb Physical, 2383mb Managed, 93 Threads,  FDs
08/28 10:35:38 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [100% buf] [PLAYING @ 0:21/6:58] Mr. P.C. - John Coltrane
08/28 10:35:43 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [96% buf] [PLAYING @ 0:26/6:58] Mr. P.C. - John Coltrane
08/28 10:35:48 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [100% buf] [PLAYING @ 0:31/6:58] Mr. P.C. - John Coltrane
08/28 10:35:53 Info: [stats] 12174mb Virtual, 4032mb Physical, 2389mb Managed, 93 Threads,  FDs
08/28 10:35:53 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [100% buf] [PLAYING @ 0:36/6:58] Mr. P.C. - John Coltrane
08/28 10:35:58 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [100% buf] [PLAYING @ 0:42/6:58] Mr. P.C. - John Coltrane
08/28 10:36:03 Trace: [Holo] [zoneplayer/raat] sync xCORE USB Audio 2.0 : realtime=3001332181181 rtt=500us offset=-59490793818us delta=65us drift=9991us in 1100.64s (9.078ppm, 32.682ms/hr)
08/28 10:36:04 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [74% buf] [PLAYING @ 0:47/6:58] Mr. P.C. - John Coltrane
08/28 10:36:08 Info: [stats] 12174mb Virtual, 4031mb Physical, 2402mb Managed, 93 Threads,  FDs
08/28 10:36:09 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [52% buf] [PLAYING @ 0:52/6:58] Mr. P.C. - John Coltrane
08/28 10:36:14 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [26% buf] [PLAYING @ 0:57/6:58] Mr. P.C. - John Coltrane
08/28 10:36:19 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:19 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [2% buf] [PLAYING @ 1:02/6:58] Mr. P.C. - John Coltrane
08/28 10:36:20 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:21 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:22 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:23 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:24 Info: [stats] 12174mb Virtual, 3990mb Physical, 2408mb Managed, 93 Threads,  FDs
08/28 10:36:24 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:24 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [PLAYING @ 1:07/6:58] Mr. P.C. - John Coltrane
08/28 10:36:25 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:26 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:27 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:28 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:29 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:29 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [43] {"status":"Dropout","samples":32538}
08/28 10:36:30 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [43] {"status":"Dropout","samples":95533}
08/28 10:36:30 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [PLAYING @ 1:12/6:58] Mr. P.C. - John Coltrane
08/28 10:36:30 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:30 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [43] {"status":"Dropout","samples":94208}
08/28 10:36:31 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:31 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [43] {"status":"Dropout","samples":98304}
08/28 10:36:31 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [43] {"status":"Dropout","samples":94208}
08/28 10:36:32 Debug: [prebuffer] sleeping in read -- this isn't good
08/28 10:36:32 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [43] {"status":"Dropout","samples":98304}
08/28 10:36:32 Warn: [Holo] [zoneplayer/raat] Too many dropouts (>3s dropped out in the last 30s). Killing stream
08/28 10:36:32 Trace: [Holo] [zoneplayer/raat] too many dropouts. stopping stream
08/28 10:36:32 Info: [Holo] [zoneplayer] advance didn't change the track. returning short read
08/28 10:36:32 Warn: Track Stopped Due to Slow Media
08/28 10:36:32 Info: [audio/env] [zoneplayer -> stream] All streams were disposed
08/28 10:36:32 Warn: [zoneplayer/raat] Error during streaming: System.NullReferenceException: Object reference not set to an instance of an object
  at Sooloos.Broker.Transport.RaatZonePlayer+<>c__DisplayClass31_0.<_StartStream4>b__1 () [0x00461] in <ae57a15c13344c4c8bfc36696ab130e5>:0
08/28 10:36:32 Trace: [Holo] [zoneplayer/raat] Endpoint xCORE USB Audio 2.0  State Changed: Playing => Prepared
08/28 10:36:32 Info: [audio/env] [zoneplayer -> stream -> endpoint] All streams were disposed
08/28 10:36:32 Trace: [xCORE USB Audio 2.0 ] [raatclient] SENT [45]{"request":"end_stream"}
08/28 10:36:32 Debug: [raat/tcpaudiosource] disconnecting
08/28 10:36:32 Info: [zone Holo] OnPlayFeedback StoppedEndOfMediaUnnatural
08/28 10:36:32 Debug: [zone Holo] _Advance
08/28 10:36:32 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [43] {"status":"Ended"}
08/28 10:36:32 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [45] {"status":"Success"}
08/28 10:36:32 Info: [library] recorded play for profile 52d3a902-e9ad-497e-b360-6cb19625acf9: mediaid=50:1:7882e5fe-c144-4560-ba7e-0939863fa848 metadataid=97:0:680671277660 contentid= libraryid=50:1:7882e5fe-c144-4560-ba7e-0939863fa848 isfromswim=False
08/28 10:36:32 Info: sleep 3ms after flush
08/28 10:36:32 Info: [Holo] [zoneplayer] BufferingTrack == NextTrack during ClearQueuedMedia, setting _stop_on_next_track_transition
08/28 10:36:32 Info: Alert: Roon: music_media_slow
08/28 10:36:32 Trace: [library] finished with 230 dirty tracks 37 dirty albums 60 dirty performers 102 dirty works 190 dirty performances 0 clumping tracks, 0 clumping auxfiles 0 compute tracks, 0 deleted tracks, 0 tracks to (re)load, 0 tracks to retain, 0 auxfiles to (re)load, 0 auxfiles to retain, and 382 changed objects
08/28 10:36:32 Trace: [Holo] [Lossless, 24/192 ALAC => 24/192] [LOADING @ 0:00] Giant Steps [Alternate Version 1] - John Coltrane
08/28 10:36:32 Trace: [dbperf] flush 0 bytes, 0 ops in 5 ms (cumulative 498173780 bytes, 549190 ops in 358337 ms)
08/28 10:36:32 Trace: [library] endmutation in 167ms
08/28 10:36:32 Info: [Holo] [zoneplayer] Playing: /Volumes/macbt/itunes/music/John Coltrane/Giant Steps/08 Giant Steps (Alternate Take).m4a
08/28 10:36:32 Trace: [analysis] prioritizing next track LibraryTrack[23962930, John Coltrane - Giant Steps - Naima [Alternate Version 1] IsAvailable=True IsDeleted=False ] for zone 22:1:7f4559ad-1928-af82-0f14-4e6673bef23b
08/28 10:36:32 Trace: [analysis] analyzing (high priority) trackid=23962930 url=/Volumes/macbt/itunes/music/John Coltrane/Giant Steps/09 Naima (Alternate Take).m4a
08/28 10:36:32 Info: [Holo] [zoneplayer] Queueing: /Volumes/macbt/itunes/music/John Coltrane/Giant Steps/09 Naima (Alternate Take).m4a
08/28 10:36:32 Info: [audio/env] [zoneplayer] All streams were disposed
08/28 10:36:32 Debug: GMS: saving nav stack
08/28 10:36:32 Debug: GMS: trying to save nav stack, but nav stack stuff was in progress
08/28 10:36:33 Info: [Holo] [zoneplayer]     Open Result (Playing):Result[Status=Success]
08/28 10:36:33 Info: [Holo] [zoneplayer] Starting playback
08/28 10:36:33 Trace: [Holo] [zoneplayer/raat] StartStream Sooloos.Broker.Transport.RaatZonePlayer+Endpoint: StreamFormat(channels=2, bitspersample=16, samplerate=44100, isdts=False) => StreamFormat(channels=2, bitspersample=16, samplerate=44100, isdts=False) streamid=1604939671
08/28 10:36:33 Trace: [xCORE USB Audio 2.0 ] [raatclient] SENT [46]{"request":"teardown"}
08/28 10:36:33 Trace: [Holo] [zoneplayer/raat] Endpoint xCORE USB Audio 2.0  State Changed: Prepared => Idle
08/28 10:36:33 Trace: [xCORE USB Audio 2.0 ] [raatclient] SENT [47]{"request":"setup","format":{"sample_type":"pcm","sample_rate":44100,"bits_per_sample":16,"channels":2,"sample_subtype":"none"}}
08/28 10:36:33 Info: [zone Holo] OnPlayFeedback Playing
08/28 10:36:33 Trace: [Holo] [Lossless, 16/44 ALAC => 16/44] [PLAYING @ 0:00] Giant Steps [Alternate Version 1] - John Coltrane
08/28 10:36:33 Trace: [prebuffer] ready 149940/441000 (34%) @ 0/224 sec
08/28 10:36:33 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [42] {"status":"Teardown"}
08/28 10:36:33 Warn: [ui/slowness] widget newwaveform(2392) took 495ms to _Update
08/28 10:36:33 Debug: GMS: done saving nav stack
08/28 10:36:33 Info: [Holo] [zoneplayer] Open result (Queueing): Result[Status=Success]
Elements:
    Source Format=Alac 44100/16/2 BitRate=873 Quality=Lossless
08/28 10:36:34 Trace: [prebuffer] ready 149940/441000 (34%) @ 0/271 sec
08/28 10:36:35 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [47] {"status":"OutputMessage","message":{"signal_path":[{"method":"coreaudio_exclusive","quality":"lossless","type":"output"}]}}
08/28 10:36:35 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [47] {"status":"Success","clock_port":59081,"audio_port_tcp":61009,"audio_port":0}
08/28 10:36:35 Trace: [Holo] [zoneplayer/raat] Endpoint xCORE USB Audio 2.0  State Changed: Idle => Prepared
08/28 10:36:35 Trace: [Holo] [zoneplayer/raat] synced to endpoint xCORE USB Audio 2.0  clock: realtime=13196839286475 rtt=500us offset=-49327822713us delta=-49327822713us
08/28 10:36:35 Trace: [xCORE USB Audio 2.0 ] [raatclient] SENT [48]{"request":"stream","stream_id":1604939671,"first_seq":-1,"nak_port":-1,"buffer_size":10,"ready_threshold":0.2}
08/28 10:36:35 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [48] {"status":"Buffering"}
08/28 10:36:35 Trace: [Holo] [zoneplayer/raat] Endpoint xCORE USB Audio 2.0  State Changed: Prepared => Buffering
08/28 10:36:35 Trace: [Holo] [zoneplayer/raat] [zoneplayer/raat] selected xCORE USB Audio 2.0  as clock master
08/28 10:36:35 Debug: [raat/tcpaudiosource] connecting to 192.168.1.191:61009
08/28 10:36:35 Debug: [raat/tcpaudiosource] connected
08/28 10:36:35 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [48] {"status":"Ready"}
08/28 10:36:35 Trace: [Holo] [zoneplayer/raat] Endpoint xCORE USB Audio 2.0  State Changed: Buffering => Ready
08/28 10:36:35 Trace: [Holo] [zoneplayer/raat] wait for ready in 9ms
08/28 10:36:35 Trace: [Holo] [zoneplayer/raat] Doing 'ASAP' Start since we are just playing to one device
08/28 10:36:35 Trace: [xCORE USB Audio 2.0 ] [raatclient] SENT [49]{"request":"start","min_offset":50000000,"stream_sample":0}
08/28 10:36:35 Trace: [Holo] [zoneplayer/raat] Endpoint xCORE USB Audio 2.0  State Changed: Ready => Playing
08/28 10:36:35 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [48] {"status":"Playing"}
08/28 10:36:35 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [49] {"status":"Success","time":13196912152896}
08/28 10:36:38 Trace: [Holo] [Lossless, 16/44 ALAC => 16/44] [100% buf] [PLAYING @ 0:02/3:44] Giant Steps [Alternate Version 1] - John Coltrane
08/28 10:36:39 Info: [stats] 11810mb Virtual, 3626mb Physical, 1508mb Managed, 93 Threads,  FDs
08/28 10:36:43 Trace: [Holo] [Lossless, 16/44 ALAC => 16/44] [100% buf] [PLAYING @ 0:07/3:44] Giant Steps [Alternate Version 1] - John Coltrane
08/28 10:36:45 Trace: [analysis] analysis completed in 13053ms for 271s of ALAC 44.1kHz 16bit audio. loudness=-19.4197283800306LUFS dbTP=-2.62742272680331 noisestartms=156 noiseendms=265330 isdts=False mqa=0 for track 23962930 url=/Volumes/macbt/itunes/music/John Coltrane/Giant Steps/09 Naima (Alternate Take).m4a
08/28 10:36:45 Trace: [library] finished with 1 dirty tracks 1 dirty albums 1 dirty performers 1 dirty works 1 dirty performances 0 clumping tracks, 0 clumping auxfiles 0 compute tracks, 0 deleted tracks, 1 tracks to (re)load, 0 tracks to retain, 0 auxfiles to (re)load, 0 auxfiles to retain, and 5 changed objects
08/28 10:36:45 Trace: [dbperf] flush 4908 bytes, 2 ops in 13 ms (cumulative 498178688 bytes, 549192 ops in 358350 ms)
08/28 10:36:45 Trace: [library] endmutation in 94ms
08/28 10:36:45 Info: [audiodevice] updating analysis info for next track because analysis finished
08/28 10:36:45 Info: [zoneplayer/signal] update playparams to gain=0dB peak=dB basems=0 noisestartms=130 noiseendms=218686
08/28 10:36:45 Info: [zoneplayer/signal] update playparams to gain=0dB peak=dB basems=0 noisestartms=156 noiseendms=265330
08/28 10:36:48 Trace: [Holo] [Lossless, 16/44 ALAC => 16/44] [100% buf] [PLAYING @ 0:13/3:44] Giant Steps [Alternate Version 1] - John Coltrane
08/28 10:36:53 Trace: [Holo] [Lossless, 16/44 ALAC => 16/44] [100% buf] [PLAYING @ 0:18/3:44] Giant Steps [Alternate Version 1] - John Coltrane
08/28 10:36:55 Info: [stats] 11803mb Virtual, 3598mb Physical, 1518mb Managed, 95 Threads,  FDs
08/28 10:36:55 Trace: [zone Holo] PlayPause
08/28 10:36:55 Trace: [zone Holo] Pause
08/28 10:36:55 Trace: [Holo] [zoneplayer/raat] Pausing at streamtime_ns 20054958373 now_ns 13216967111269
08/28 10:36:55 Info: [zone Holo] OnPlayFeedback Paused
08/28 10:36:55 Trace: [Holo] [Lossless, 16/44 ALAC => 16/44] [100% buf] [PAUSED @ 0:19/3:44] Giant Steps [Alternate Version 1] - John Coltrane
08/28 10:36:55 Trace: [xCORE USB Audio 2.0 ] [raatclient] SENT [50]{"request":"stop"}
08/28 10:36:55 Trace: [Holo] [zoneplayer/raat] Endpoint xCORE USB Audio 2.0  State Changed: Playing => Paused
08/28 10:36:55 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [48] {"status":"Stopped"}
08/28 10:36:55 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [50] {"status":"Success"}
08/28 10:37:00 Trace: [zone] no playback for 5s, suspending to release audio device
08/28 10:37:00 Trace: [zone Holo] Suspend
08/28 10:37:00 Trace: [zone Holo] Stop
08/28 10:37:00 Info: [zone Holo] OnPlayFeedback Stopped
08/28 10:37:00 Info: [audio/env] [zoneplayer -> stream] All streams were disposed
08/28 10:37:00 Trace: [Holo] [zoneplayer/raat] Endpoint xCORE USB Audio 2.0  State Changed: Paused => Prepared
08/28 10:37:00 Trace: [xCORE USB Audio 2.0 ] [raatclient] SENT [51]{"request":"end_stream"}
08/28 10:37:00 Info: [audio/env] [zoneplayer -> stream -> endpoint] All streams were disposed
08/28 10:37:00 Trace: [xCORE USB Audio 2.0 ] [raatclient] SENT [52]{"request":"teardown"}
08/28 10:37:00 Info: [audio/env] [zoneplayer] All streams were disposed
08/28 10:37:00 Trace: [Holo] [zoneplayer/raat] Endpoint xCORE USB Audio 2.0  State Changed: Prepared => Idle
08/28 10:37:00 Debug: [raat/tcpaudiosource] disconnecting
08/28 10:37:00 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [48] {"status":"Ended"}
08/28 10:37:00 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [51] {"status":"Success"}
08/28 10:37:00 Info: sleep 3ms after flush
08/28 10:37:01 Trace: [xCORE USB Audio 2.0 ] [raatclient] GOT [47] {"status":"Teardown"}
Hello @Peter_Galvin1,
Thanks for posting those logs. Sleeping in read generally means that the media didn’t get delivered to the endpoint in time. I would like to separate the possible causes here with the following test:
  1. Please disable all of your local watched storage locations
  2. Use only TIDAL as the media source
  3. Verify if the same issue occurs every 10 tracks when outputting on the same endpoint
