I haven’t been using Roon for a few weeks or even months. And now nothing seems to work anymore…
Roon server runs in an Unraid docker. At least this part seems to work.
IOS app:
When opening the app, it shows me my “Roon Core” with a green signal and “ready”. Built 795
When selecting “configure roon os device”, it idles out
When trying to log in, I get an error message “invalidremotedata”
WIndows app
Screen is blurry and green. I saw this is a common error. Updating Intel drivers did not help
When trying to log in, it also fails. Screen is too green / blurry to see. But I guess same error as on IOS?
dylan
(Dylan Caudill)
June 28, 2021, 10:43pm
2
Hi @steve77
steve77:
WIndows app
Please see this post:
This issue is caused by a bug in Intel’s GPU drivers that causes graphical corruption with applications that utilize 30-bit (“deep color”) frame buffers. We encountered this bug during the development of Roon 1.8, but it has been fixed in Intel’s driver releases since July or August of last year.
To update to the latest GPU drivers, use the Intel® Driver & Support Assistant.
If you cannot (or do not wish to) update your GPU drivers, you can disable 30-bit color on Windows by adding the -nodeep…
steve77:
Can you elaborate a bit on your networking setup? Normally this is a network-related error.
We’ve seen switching to Google DNS help in the past, definitely worth giving that a try.
Thanks for your message. Will try to disable 30bit.
My network setup is “normal”. it used to work flawless and I haven’t changed. WIfi with Apple Airport Extreme.
Any more thoughts. I can no longer use Roon. I tried from iphone app, ipad app and also from Windows, I am seeing always the same error (“invalidremotedata"). I switched to Google DNS, but no change.
noris
Closed
April 7, 2025, 9:35pm
5
