Roon stopping Audio playback after Audio reset request
Intel Core i7
16GB RAM
Windows 10 Pro
100M/b Ethernet.
LAN connection between Roon Core and Remote without WiFi.
Yamaha R-N2000A via USB DAC
100
USB DAC windows ASIO driver issue Audio reset request for changing Audio sampling frequency.
Roon stop Audio playback after Audio reset request
ASIO driver use yamaha Staingberg USD Driver.
Hi @yasuyoshi_s,
Thank you for reaching out. Since this issue concerns a Roon Partner, our Partners team will follow up directly through appropriate channels.
Are you able to replicate this error using DSP within another audio app, like Tidal/Qobuz/KKBox?
We can reproduce the issue internally using Roon with another Yamaha network receiver, so our team will also investigate internally.
You can reproduct this issue as following products.
yamaha R-N2000A, R-N1000A, R-N800A, A-S801
Those products have USB DAC input.
USB DAC input is set to Roon Audio output.
When Audio sampling frequency is changed to 96khz from 44.1kHz.
USB DAC windows ASIO driver issues Audio reset request.
