Hi there,
My set-up is as follows;
The core is…
iMac 2013 (Late 2013)
2.7 GHz Intel Core i5
16BG 1600 MHz DDR3
Roon Version 1.6 (build 401) stable (64bit), using Tidal.
Modem ZTE ZXHN H268A http://exewiki.exetel.com.au/images/6/66/ZTE_ZXHN_H268A(V1.1)User_Manual_EXETEL_09_Feb_2017.pdf
https://business.exetel.com.au/files/modems/ZTE_ZXHN_H268A_Brochure_Exetel.pdf
KEF LS50 Wireless firmware V2.1.0 (Using 5Ghz network)
From the router to the iMac I have tried both ethernet and Wi Fi.
The problem I’m having is when I set Roon audio device to stream wirelessly to the KEFs I have random issues, from music stalling or not playing at all.
If I change my audio device from the KEFs to the systems output I have no issues, the solution I have is to run optical to the master speaker and I have no dropouts.
Also another problem which may be related is the KEFs drop of Roons network list.
I’m not really that technical any help would be much appreciated.
Cheers,
John
