Hey Brian, that does seem like a bug in that versions meta-data. Did you try looking at a different version and seeing if it was a better match? In your pics, if you look under the album pic you’ll see a “1 of 9” version selector. Try going to the other versions and see if one of others matches your music better.
Yes, I’ve looked at all the different Bond albums, and this is the correct album. I think I would call it “input error” on the part of the metadata provider. They probably had a human inputting data, and for some reason put two songs in twice, but then who knows.
I actually didn’t even realize the “1 of 9” so I’ll look closely at that!
I looked and there are 9 different versions with the same album cover. I found a better fit for the data, but it too has an error. One song appears twice: “The World is not Enough”. It’s better than 2 songs appearing twice!
Yep, if there is a version which fits better that is what I choose, so even though my album might be a digital download, I’ll choose the CD version if it fits better. But, I manually tag my albums with source origin in the “Version” section, so I’m not overly concerned if the “version” I chose to populate the database is the same as the one I really have.
Hey @BLH – I see some errors in this album’s metadata, so I’m moving this topic. @jeremiah and I are going to discuss, but for now, you should be able to use the track titles from your file tags by following the instructions here.
I have had a similar issue with various cds tracks appearing twice - Ive gone and fixed the tracks, by ticking the additional track boxes, removed the addional tracks, created new album with fewer tracks hopefully, only to find the new album has 1-1 with two versions of the track relisted.
Can you tell where I’m going wrong with the above process?
But why are duplicate tracks appearing in the first place?
Just set up roon
Like some others having problem in some albums with multiple copies of the same track which only appear once in the source files from iTunes
is there an easy way to clean up duplicates
everything i have read sounds very time consuming
this is potentially a deal breaker for me
