Mac os core latest versions of everything with all updates and dutch dutch 8c speakers.
Last night before i went to bed i was listening to this track around middle volume. I paused and went to bed. This morning when i got up roon is at maximum volume (even beyond my safety limit which requires clicking the plus icon). I now know to check volume first because i have woken the whole family by clicking play and having the music come out at max.
Another bug is that i adjusted the slider down and then clicked play, but roon resumed at the volume level i last used last night - Not at the volume level i just set the slider to!
Thanks for reaching out and sorry to hear about the difficulties here, this does not sound like a pleasant experience at all to go through. I have a few clarification questions:
Do you have any Roon extensions active, such as Logitech Harmony or some other type of volume control?
Did you only notice the issue on the 8C zone or was this occurring for all zones in Roon?
What does the rest of your Roon setup look like?
### Roon Core Machine
Include your operating system and machine info (Model, CPU, RAM)
<!-- Write below this line -->
### Networking Gear & Setup Details
Your network gear (model of routers/switches) and if on WiFi/Ethernet
### Connected Audio Devices
Specify what devices you're using and their connection types, like USB/HDMI/Chromecast, etc.)
### Number of Tracks in Library
Tell us how large your music library is, eg. "30,000 tracks"
<!--Write below this line-->
### Description of Issue
Tell us about the problem you're having in as much detail as possible. Screenshots are always appreciated!
If the issue occurs again, can you please note the time + date + track impacted and use these instructions to upload a set of Roon logs to our drive?
mac imac with monterey os latest version, 4ghz quad core, 32gb ram
Core is connected by ethernet to wifi router - have tried 2 different wifi routers. Roon remote is used on mac os and ios all latest versions of everything
Have you noticed this issue occur since your post? I noticed you uploaded a log set, but I didn’t see any rapid volume changes in the recent logs. Please check your firmware on the 8Cs and if you notice the issue, any additional info you can provide (the track playing / time of occurrence, or when you noticed) would help, thanks!
