Andrew - I did not try the search for new core option. That is what made the difference. Awesome support as always!
Thank you,
Thank you,
OK. So like setting up a new core? Does this do anything to the existing database, ect?
OK. So this is the ticket!
@ work, but will try when I get home!
Thank You Andrew!!!
Deleting and installing the core deletes the database as well. If you donât have a lot of playlist or metadata edits this doesnât really matter Roon can rebuild your collection from scratch. If you do have a lot of playlist or metadata edits you can just restore the database from a backup.
I also deleted the Roon Core on the SonicTransporter and reinstalled using the following steps:
I went into âSoftware Managerâ, went to âInstalled Appsâ tab, clicked Roon Server, and selected âDELETEâ. Rebooted the sonictransport, went to âAvailable Appsâ tab, and installed Roon Server.
Rebooted the sonictransporter again. Waited until it launched and then went to one of the Roon Endpoints, clicked it, and the same problem appeared: âWaiting for remote core âŚâ I did NOT select the âSelect a different Coreâ tab.
@agillis pointed out that I must âSelect a different Coreâ, which I subsequently did and was able to connect my Endpoint.
However, I had to reestablish my connection to my NAS, reconnect my backup location, and scroll through my Roon Backups until I found the most recent backup, in this case, July 3rd, 2022.
Restored the backup in ROON and - VOILA - all is back to normal. All playlists, all endpoints, all DSP settings - everything.
I canât stress how important it is to monitor and verify your ROON backups as it will save your bacon. I also take screenshots of my setup just in case of some disaster that forces me to set up ROON from scratch.
Thanks to @agillis for helping out.
@agillis Thank you for assisting in this thread! Iâve marked it as a solution for now. If anyone runs into additional issues, please read through this thread and let me know if any issues persist.
All the best,
Ben
Thanks, Andrew!
Thanks for the detailed instructions! Will get it done tonite!
Fantastic.
