Ethernet Orbi router
Chord Poly
I just bought and downloaded Motown 69. I can not see the directory in Roon. I painstakingly added each and every artist… because the fine folk at HDTracks just put various. The files are .flac & I don’t see the directory when I go to select the folder via the storage menu.
Click “Overview” from the top left Menu, is it the first Album in the list? If you added every artist as “Track Artist”, the “Album Artist” should still be “Various”, otherwise you might find you’ve a load of one track albums. The “Album” should be exactly the same for all tracks too.
It showed up this morning… the weird part is I could not even see the folder to add it to the watched folders list. I do this with new additions to avoid waiting for a scan. Thanks for the help MJB
